Hi guys, building a new PC for a fiend and unfortunately it's not posting at all... I'm stumped. :s
I turn it on, the hard drive starts up, the card reader lights up, all 3 fans come on, but NO BEEPS, and nothing to monitor. My main problem is once its turned on, the only way to turn it off is to cut the power supply switch - i would try more stuff but im scared of damaging parts by turning it off this way. Also my IDE CD drive wont open, not suprising.
thought i cud be a system builder, my confidence has been well knocked...
mobi is an ASUS M4A785TD-V EVO
cpu is an AMD x3 445
ram is 2x2gb of OCZ ddr3 1333, low voltage edition ram (might this be the problem? I think the lower voltage stuff is used for i5, and i7. Would the PC still post or bleep with non working/compatible memory - or no memory at all?)
power supply came with a coolermaster elite 330 case
460W product no is rs-460-pcap-j3
Also have a gainward passive cooled 8600GT to try and get working with this
500gb WD caviar
I have a PCI POST tester card, and that does nothing (waste of money that was).
I have tried the following with NO changes...
>Moving the ram around, and then only trying one stick in a couple of slots (wheres it supposed to go? Asus just says
>I will try leaving the CMOS chip out overnight now to see if that works
>checked all connections
>unplugged the HDD, CD, and card reader (so its just the cpu and one dimm in the mobo).
CLUES
I gotta be honest im VERY confused about the power connectors on my mobo... maybe this is where ive gone wrong.
The power supply has the usual big 20 pin motherbaord clip with "P1" on it - is this supposed to be missing one metal pin?
Close to this is also 4pin plug with "24" written on it. again looks normal, has 4 pins and orange/yellow/black/red cables. But it dosent seem to fit perfectly in the slot, unless you put it in 1st (which is what ive now done).
BUT there's also another two 4pin cables (blackx2/yellowx2) one with "P2" on it. Why do i have two for one CPU!? - they have different slots but both fit. Which one shall i use?
What do youguys reckon?
Hopefully hear from ya in the morning guys!
500gb WD caviar
CLUES
