Caporegime
- 11 Mar 2005
- Leafy Cheshire
looks cool, isn't useful.
Sorry but what?
yeah, if you jump through every hoop of getting the right oil quality, thickness, temperature, atmospheric conditions, and the if your gauge is at all accurate (which you'll never know)
1) Oil Quality, not an issue why would you be using anything except what the manufactures specifies? Doesn't really matter on brand long as the viscosities are correct.
2) As point number 1
3) Temperature, you should have a cold and hot readings, long as the engine is working correctly and within the manufactures temperature range, this isn't an issue.
4) Atmospheric Conditions, what are you taking about here elevation above sea level? Otherwise it's as point 3.
5) Are you saying that an oil pressure gauge which is manufactured and tested before shipping to ensure an accurate reading to +/- whatever mb is going to be so far out you can't trust the readings, does this happen with all gauges, can i trust any of them ever, if not what should i use instead, guesswork, seems you like that?
