I am upgrading my system and will be watercooling and overclocking.
Was going to get am i7 930 or a 2nd hand 920 but then the 950 dropped in price.
But after reading around it seems to make little difference as to whether you get an 920 or 950 as the i7's all seem to hit a max overclock and it's just pot luck whether you get a good/bad clocker. With a decent mobo it appears you can set a BLK much higher than even the 20x multi of the 920 can handle eg the max speed is limited by the cpu.
So is it worth my bothering getting the 950? Or even the 930 and just get a 2nd hand 920?
Equally on reading around searching for my answer, I keep seeing 1156 i7's performing better clock per clock than their bigger brothers. Do these overclock as well as them as I can save money on both the cpu and mobo.
I thought I knew what I wanted but now stuck again.
