- 23 Apr 2009
- Cheshire
So from a gaming perspective what would your answer to Eulixe (or anyone else reading) be now?
And the answer to that question is most likely "no" - though it does depend on whether Eulixe plans to add a load of graphics cards in crossfire/SLI (which can also be served well by a x16x16 PCIe AMD system). But if he is just gaming with a single card then an i5 or AMD AM3 Phenom II X4 would make much more sense.
However, he also mentions photoshop and audio work. The i7 is marginally faster, imho not worth the extra money, but obviously its up to the OP.
For Adobe Audition the program can make use of many threads and hyperthreading, so it conceivable that the i7 will be a bit faster. However, I can't find any benchmarks which compare i7 to i5 and from the sound of how the OP will be using the software (work on a podcast) I'm certain the i5 will be fast enough.
Hopefully with this info and the info posted by everyone above, the OP can come to an informed decision about his new PC that best suits his needs and budget.
