there is no way a small claims action will be sorted that quickly - it will take 6 months if you're lucky.
And there's no such thing as a small claims court![]()
Agree to buy the vehicle for £2400
Go through small claims court
Man up and accept ive lost £400?
Well hery majesty's money claim online which is linked on the small claims court site is what i will be using. I have used it before with a 'Denim' incident and it was sorted in less than 30 days.
Erm. Do you mean with regards to the problem or the way he told me about it?
I received a text out of the blue on Friday saying:
"when you come, i would recommend bringing a jerry can to fill with fuel just incase. The car doesnt like running sometimes with 1/4 of a tank"
I responded: "why doesnt it like running if it only has 1/4 of tank?"
He said: "Well it does, but when you boot it for a long period of time say down the motorway, the pump wont keep up with the carbs. Its not designed for that. Also, when low on fuel and going round corners the fuel is swishing from side to side and the pump wont always get fuel when it is low. I tend to always keep it above half to be on the safe side."
Basically after speaking with my mate who is a mechanic he said "Its Fuel surge and the fuel tank and pump arent the right ones for the 2.0litre engine"
After letting the owner know this he said: "The car is right. All i mean is keep the fuel above half for the long journey home down the motorway. I have never had a problem with it and if you really want a tank for it they came on the later fiestas and you can pick one up for £20. Im just trying to help you out here and make sure you dont have any problems with the car".
So there you go. He mentioned the problem to me... but he said it isnt a problem and he hasnt ever experienced it.
oh, that was you?
there's still still no such thing as a small claims court. how did you get that sorted so quickly - it can't have gone throught the court process??? Did they just settle before a hearing?
If you have his address and he isnt on the other side of the country I'd turn up at his door and politely request my deposit in person.
Bring friends.
i'm sending off the claim now, is this okay as the short description:
I agreed to buy a car from Jon Hunt for £2400
and paid a deposit of £400. The advert
described the car as being mint condition and
ok as a daily driver. The seller said the
earliest i could pick the car up is 26th
September as he needs it for work until then.
I asked if there were any problems with the
car which he said there was two. One with the
rev counter and the temp gauge. On Friday
September 10th the seller text me saying:
'when you come, i would recommend bringing a
a tank'. I said: 'why doesnt it like running
if it only has 1/4 of tank?'. He said:'Well
designed for that'. I am due a refund of my
deposit because the car was missold. No
problems and everyday runner were clearly
mentioned in the advert, this car is neither
an everyday driver nor without problems.
I still want the car but only if its fixed.
Fuel surge is what you would get if you used a "carb fuel supply system" on a fuel injected engine. As the engine in this case has carbs, and he has probably fitted an electric fuel pump (since the engine would have been injected previously and it wouldn't have any form of mechanical fuel pump on it) I would say that the car probably only needs a new fuel pump of the correct rating. It shouldn't need a new tank at all.
It could also be likely that the fuel gauge is still not reading correctly and that when it says it is on 1/4 tank it could be much less than that. I had a few mk2's and they never were the most acurate.
eh? I thought you were taking him to court to recover your deposit.
I doubt you're able to get a CCJ forcing him to make a modification to a car you want to buy.
Also you might want to remove this "I am due a refund of my
deposit because the car was missold. " - The court decides whether you're due a refund and the car hasn't been sold yet.
IMO simply state that you've asked for your deposit back as a result of this new information as you no longer wish to purchase the car under those circumstances and the seller has refused to reimburse you.
