php splitting up strings
4 Mar 2007
United Kingdom
Ok so I have found through a very annoying way that my system will not work on my own server as it's using php 5.2 and my hosts refuse to update. Thus I cannot use the boolean within strstr and it has to be used with the 2 arguments instead of 3 strstr($stringName, ':', true);
This means now I cannot find elements of a string on the left or right, just one side.
For instance my string structure is:
firstElement&secondElement:thirdElement
I initially had it doing this:
PHP:
$_first = strstr($myString, ":", true);
$third = strstr($myString, ":", false);
$first = strstr($_first, '&', true);
$second = strstr($_first, '&', false);
but I cannot do this as I get a warning which is a bug with anything from 5.2 as it only works with 5.3 are there any other ways I can do this?
Regards,
14 Feb 2006
Surrey, UK
PHP:
$initial = "first&second:third";
$amp_pieces = explode("&", $initial);
$first = $amp_pieces[0];
$c_pieces = explode(":", $amp_pieces[1]);
$second = $c_pieces[0];
$third = $c_pieces[1];
Messy I know, but should work...
fez
fez
Caporegime
22 Aug 2008
Tunbridge Wells
GeForces method should work perfectly. Is there any reason why you are using different separation characters for the 3 parts? Do you have no control over the format of the string?
OP
4 Mar 2007
United Kingdom
Basically the system uses two types of delimiters which are assigned from a relationship tree that I have no control over. These are put together from $_POSTS the user enters into the application. There is more code behind assigning the delimiters throughout the application than there is identifying the separate parts and running the query on the first, second third.
Hence the two delimiters are used.
26 Dec 2003
London
Bit shorter and a bit more extendable, if you want:
PHP:
<?php
$s = 'first&second:third';
preg_match('/(.*)&(.*):(.*)/', $s, $m);
list(, $first, $second, $third) = $m;
19 Jun 2010
Southampton City Centre
$m =
"If m is provided, then it is filled with the results of search. $m[0] will contain the text that matched the full pattern, $m[1] will have the text that matched the first captured parenthesized subpattern, and so on. "
Think of it as an array
19 Jun 2010
Code:
<?php
$str = 'foobar: 2008';
preg_match('/(?P<name>\w+): (?P<digit>\d+)/', $str, $matches);
/* This also works in PHP 5.2.2 (PCRE 7.0) and later, however
 * the above form is recommended for backwards compatibility */
// preg_match('/(?<name>\w+): (?<digit>\d+)/', $str, $matches);
print_r($matches);
Would output
Array
    [0] => foobar: 2008
    [name] => foobar
    [1] => foobar
    [digit] => 2008
    [2] => 2008
from php.net
OP
4 Mar 2007
United Kingdom
$m =
Code:
<?php
print_r($matches);
Would output
Array
    [0] => foobar: 2008
    [name] => foobar
    [1] => foobar
    [digit] => 2008
    [2] => 2008
from php.net
Ahh, ok brilliant I will just dump the thing into a function and apply it throughout my site then.
Cheers all again for the helpful advice :)
