Antec TruePower 550w = i7 930 @4ghz + GTX470?
30 Sep 2005
Hi all,
Just about to order a GTX470 and wondered if my PSU would be ok. Don't really want to have to spend out on a bigger one but if I HAVE to then I have to.
Rest of the kit in sig
Thanks!
Hi all,
Thanks!
It should be fine, but if you want to check how much power you are actually using you can always try our wattage calculator, which is quite in depth and even takes the age of the capacitors into account when deciding how much power you will need.
http://www.antec.outervision.com/
