photoshop my bedroom mirror for me
7 Sep 2008
hi guys putting up a mirror for my bedroom sink unit:
spoke to local shop he was saying that is it 4mm or 6mm
im thinking two mirrors one on the front one on the side....
what should I go for? also where the walls meet up what can I put there?
I need to give him dimensions today. I'm yet to measure them out but should I go all away across the tiles? tiles staying there btw long thing.
how and where would you put it up? photoshop ppl welcome
2 mirrors at right angles would look rubbish imo
i'd have one decent sized mirror with lighting and one of those magnifying ones with a small light on it
Just butt the two mirrors up to each other? There is no need to put anything where the red scribble is.
If you then silicone the joints and edges it will increase the size of your splashback and be easier to clean.
ah okay cool
should I get a beveled, polish or straight finish
still not sure about thickness? 4mm should be okay
