Okay, new build coming on well just need tubing and fittings and coolant.
Build so far is:
I7 950 cpu
Asus P6X58D-E
Corsair 3 x 2Gb XMS3 8-8-8-24
EK Multioption Reservoir X2 150 Advanced
GTX470 with EK waterblock
XSPC RX360 with fan shrouds and 3 x San Ace fans
two x fan controllers
Laing D5 pump with EK V2 aftertop
Swiftech Apogee XT CPU waterblock
Corsair 800D case
Seasonic M12 850W psu
Xonar D2X
I plant to "butcher" the 800D later and add my existing 240 rad and san ace fans in the bottom.
Current plan is just one loop for now but may split into two loops when I add another gtx470 later.
Just can't decide over tube now. Currently have Tygon 7/16" thick wall tube which is ace and served me well but not great at bending and I will never have enough peices of the correct length for the new build.
SO I was thinking 7/16" tube again but you appear to be very limited in choice for that size. I want uv blue and I am going with distilled water plus nuke plus silver coil. I seem to be only able to find XSPC in this size/colour but no idea how/good bad it is.
1/2" opens up a world of choice especially PrimoFlex Pro LRT but just not sure whether it would just look too chunky if you know what I mean?
Once last question cause I can't remeber: fans on rads - better to pull or push?
Cheers.
Build so far is:
I7 950 cpu
Asus P6X58D-E
Corsair 800D case
Xonar D2X
Cheers.
