I may be being thick but...
Caporegime
28 Jun 2007
Tamworth, UK
Why is one core speed massively different?
I think that for a forum member of your experience you MAY have posted a tester to see if anyone can figure it out?
My theory is
That you have loaded AMD Overdrive
In advanced mode you have knocked the Core 0 multiplier back to x4
Applied the change
Run Speccy and taken a screenshot and posted it to test us.
In the meantime reverted the change in AMD overdrive and run OCCT and taken another screenshot ( just before it finshes ) and posted that
It's just a guess :)
I bought a Gigabyte UD5 and X1090T shortly after release and this was a bug at the time, for some reason disabling the power saving features were not working for the first core, they were supposed to be releasing a BIOS update to fix it but I got impatient and got rid.
So try updating your BIOS?
