I am differently not mistaking Egypt with Iraq. If your research failed to take note of what I mentioned then you cannot have done much research. Surly the shear amount of people on here saying the same thing should be setting off alarm bells for you.
It doesn’t take much research to find out Vendettas are common among clans in Egypt and there is a lot of tension between communities more so Christians and Muslims with deaths.
EDIT: From what I can gather the south of Egypt is much worse than the North. Which area are you planning on moving to? If it’s the south you should really re think or do some real research.
Are you liking it there?... time to go home, I won't be able to reply until I get home (now for a 1hour 15min commute home, yipee!)
