New PC time, noob assistance
29 Jan 2007
Hi Guys, looking at building a new pc at some point.
Ive been out of the "game" for a while now but got a massive urge for K+M FPSers. My old PC was a AMD 3200, ATI x800 lol old school
Please can you look at my spec and make some recommendations etc
Argon Extreme Intel Core i3 2.93GHz @ 4.20GHz Overclocked Bundle £264
Intel X25-V Value 40GB 2.5 £82
Antec 300 £49
Corsair CX 400W £33
GeForce GTX 460 1024MB (not sure which one) £180??
=600 ish
I will be gaming on a 24" at either 1920 or 1650
I have a Sata DVD drive
Windows X64
I need recommendation on a keyboard and a mouse I used to have a
Saliek gaming keyboard
razor diamondback
Looking for something similar?
Is there anything really crap Ive missed out, do I need fans for the case would like one awesome 120mm really.
Thanks very much, any comments much appreciated
Hi guys thanks for the replies,
Yeah its Win 7 64, also I have got an old 500gb sata but I will throw in a 1tb at xmas.
Is the PSU ok? I really have little knowledge of these.
I think I'll get that gfx card then comes well reviewed! and its £173! this week
Any keyboard/mice that are similar to the ones i listed?
Thanks again
Chris
Using a Microsoft Sidewinder X8 Mouse at the moment. Very impressed by it, although you need quite big hands otherwise its a little uncomfortable to be honest, weight is good and is wireless.
Ive never been a fan of logitech mice, but I see that comes well reviewed!
Would you recommend wireless for gaming? I had a microsoft one ages ago and I think I ended up chucking it!!!
^^ thanks for the info! is it worth going modular? Is the only benefit airflow and aesthetics
I wont be windowing the case. Also in regards to case fans do I need a 120mm? and can you recommend one?
