- 25 Sep 2009
- Billericay, UK
the X48 doesn't really offer much over an X38 except official support for higher FSB which can be reached with an X38 via overclocking. However if the X48 is around the same price might as well go for it.
The P45 is a newer chipset so its a bit better than X38/X48 but only if your using a single graphics card, in your case you want to go tri X-fire so X38/X48 will be better than the P45.
Doesn't X48 offer PCI-E 2.0 whereas X38 uses the older PCI-E 1.0 standard?
