You mean your PSU, not your CPU. Anyway the answer is probably not, check your motherboard as some will still work with a 4 pin 12V ATX. Also check your PSU manual there's more than one type of 4 pin power connector.
Andi.
There you goYou can usually plug in just 4.
The 8 pins are similar but have a different style of connector. Got a piccy of them?
The 2 x 4pin plugs are for your 8pin motherboard. They will only go in one way. They are designed to give a cleaner/stable voltage to the cpu rather than a single 4 pin plug (which will also work).
I'm stupid.
