- 29 Aug 2010
- Cornwall
Wasn't sure if this should go in the "Cooling" section or "CPU" section of the forums, so opted for here.
At the moment I'm running a Phenom II X6 1055T (95W version apparently) on a Gigabyte 880GM-UD2H motherboard with a Titan Fenrir cooler using the default Fenrir fan.
Checking in the BIOS my CPU temp was reading 45C (CPU overclocked to 3.8GHz). As this is in the BIOS, that's idle temp!
I reverted back to stock speeds (well loaded Optimised Defaults, which seemed to take it to 3.3GHz?) rebooted and checked again and the temperature read 29/30C.
Are these high for idle temps with a Titan Fenrir?
My E6850 with stock cooler is currently reading about 27C on both cores according to Real Temp. My i5 750 @ 3.8GHz (CM Hyper 212+) idles at around 38C according to CoreTemp.
Based on this the readings I'm getting for the Phenom seem high.
Also, how do you know when to stop tightening the thumb screws on the Fenrir (specifically on a AM3 board)?
I don't want to do them too tight that I damage something, but I don't want it too be too lose that it's not making good contact.
Thanks in advance for any assistance/info.
