Actually I think they all benefit from high speed fans if you can live with the noise.
And cfm or fan speed doesn't scale with the static pressure capabilities of a fan, there are plenty of fast fans with rubbish static pressure and slow fans with great static pressure.
I agree in terms of matching the rad to the fan but sometimes its not easy to do, e.g. swiftech rads often overlooked because they look skinny actually are pretty competitive.
What the OP hasn't said is whats his noise/performance threshold. Does he want to change the fans because he wants better cooling or does he want to change them because he wants quieter cooling? Or does he want both? The problem with the pre-built kits is that sometimes changing the fans doesn't help much, or not in the way that you expect.
From looking at reviews (The
HardOCP one is great) you can actually benefit a lot by switching the Coolit's fans into push mode, and benefiit again by getting a couple of matching fans and making it push/pull.
Also how is the radiator setup in your machine? Vertically? Or Horizontally. That can have an affect on the fan reccomendation, e.g. I'd reccomend a Yate Loon setup for push/pull but if you have your radiator mounted horizontally then they aren't the best fans to orientate in that way.
