- 27 Apr 2004
- In bed with your sister
Good morning.
Bought myself an aquarium water chiller for some extreme watercooling. The cooling system is working like a charm with considerably lower temperatures than standard watercooling.
I'm having trouble with the overclock though. I bought myself an i7 950 in the hopes of getting a stellar OC but I'm struggling with it - problem is, I can't get to grips with i7 overclocking. It's taken me two days to get a stable OC at 4.4GHz. That's with a vcore of 1.55V and QPI/VTT voltage of 1.45V - all other voltages are on auto (basically because I don't know where to start with those). At the moment, I'm on a 21 multiplier and a BCLK of 210. I've tried various combinations of multiplier and BCLK to get higher with vcore as high as 1.6V and QPI as high as 1.55V with no success.
System spec:
Case - Akasa Eclipse 62 (had this for 5 years and still love it).
MB - Gigabyte EX58 UD3R
CPU - i7 950
RAM - OCZ Obsidian 6GB (3x2GB) DDR3 PC3-12800C9 1600Mhz Triple Channel Kit
GFX - Powercolor HD 4890
Cooling:
Chiller - D-D DC750
Pump - Swiftech Laing D5 Vario MCP655
CPU block - Heatkiller 3.0 LT
Res - XSPC single bay res
Tubing - 1/2" black XSPC
Fittings - EK Polished Nickel Plated Brass G1/4" (BSPP) Thread to 1/2" Hose Tail
I would like some suggestions from anyone who has been higher. I suspect I may get more if I fiddle with other voltages/settings but I really don't know where to start. Any help would be appreciated.
I'll be a bit miffed if I can't get higher than this - I suspect I could have got the same OC with the 920 I replaced with the 950.
For information, CPU temps at current OC/voltages are 28-30C idle and 58-60C under load with water temperature set to 15C. I can reduce the water temperature to about 10C without causing condensation so further cooling is available.
Also, I managed to bork my GTX295 when I fitted the waterblock. I was very careful and wasn't aware of doing any damage but, when I went to boot up, I got the beep code for faulty graphics
I've stuck in a 4890 to tide me over for now. It was always my intention to stick a couple of WC'd GTX460s in there but I'll be gutted if the 295 is ruined - it was a cracking Folding card.
System spec:
CPU - i7 950
Cooling:
Chiller - D-D DC750
