Reading the post there shows that rjkoneill had a 5C drop after all the cloudy stuff dropped out and the fluid started running clear, so I'm guessing Skinnee tested it straight out the bottle. I would be more worried about where all that stuff disappeared to.
correcto
nanofluid requires around 24 hours to 'bed in'
it looks insane straight out of the bottle and there are no particles in it, its just cloudy, from my testing, it seems that it reacts with the interior of the loop.
it it much thicker than water with a sort of 'thin oily' consistancy. the reason the tests are showing poor results for it is because it takes a long time to work properly. but the suspended particles do not break down the same way as a dye or additive and they certainly do not clog up blocks.
due to nanofluid being thicker than water, it needs the pump to be set higher too. i am guessing that the Swiftech MCP355/Laing DDC3.2 with XSPC V3 Top that was used in the test was not the best pump for the job
maybe a D5 vario with an adjustable pump speed would have been better.
im not fussed about defending nano fluid because it has worked well for me, it just appears that the testing is flawed.
PT nuke clouds toobin?!
yup, the numerous threads about it on this section all confirm it.
Example
the unrelenting fascination that we have for the God like combination of PT Nuke and Distilled is really quite hilarious.
it is always especially funny to see the threads that follow when a user is advised to use ptnuke and distilled, it generally involves said user Crying Alone as their £30 worth of tygon tubing inevitably turns into a murky mess.
For my next build, I plan on using holy water in my loop.
i simply don't trust anything else
It's copper sulphate based right? Will it do anything to nickel coatings?
no it wont. its to do with the material that tygon is made from. certain types dont do it. and you are only supposed to use a little of the PT Nuke.
handling PT Nuke is very dangerous, because of its unsurpassed, miraculous biocidical properties it could wound or even kill if used incorrectly.
it has built up quite a reputation and gained a cult following [who enjoy cloudy tubing] due to its wonderous capabilities.
