A clean car!
27 Jul 2010
Bradford
I have a midnight black car...
What is the best polish/compound/wax to get it shiny?
What is the best method for polishing a car?
What do you use and how do you do it?
I always prep my cars with Autoglym at least twice, using the shampoo, resin polish and sealant. Then, after every wash it gets finished off with one of those wet wax polishes that enable you to start with a wet car, spray this stuff on and just wipe it off until dry.
If the original black isn't too good there a black vehicle detailing kit made by Turtle Wax.
Andi.
Autosmart
Platinum
A premium wax polish for new and quality used paintwork. Quick and easy to use. Platinum's advanced polymers bond to the surface, making it weather resistant & giving a long-lasting, deep shine.
