First off would like to say a very big thankyou to everyone for the advice over the past couple of months, has really really helped a lot!
Just finished my first ever build, and ironically i was stuck on the megahalems for about 2-3 hours.. i really couldnt figure out how the clips held the fans on in push/pull config, resorted to using cable ties but it isnt the most secure fitting.
As the instructions are very poor could someone please tell me how its meant to be done? :\
Although getting incredible results from the megahalems in push/pull in a coolermaster HAF X case, idles at 20 and full load at 26 according to AMD overdrive.
But again though thankyou all so much for the advice I really do appreciate it
Mehmet
Mehmet
