Recommend a courier
23 Sep 2006
Wiltshire
Hello, I need to send a car seat within the uk and need a courier that's not too expensive, can anyone suggest one?
Always use Parcel2Go and never had a problem with them or the courier I have chosen. :)
Hmm, thanks for the suggestions guys, as its a car seat i'm sending it's a rather awkward size, if i put in the dimensions 70x65x90cm then i get quotes from £45+ which is a lot. But if i massage the figures a little to 60x60x80 then i get a quote of £5.95 with the home delivery network, how strict are they about dimensions?
They certainly don't come in with a measuring tape at hand but you never know :p
Most couriers will have a revenue protection system in place. So bulky cons with a low declared weight will be measured and charged volumetrically when back at the collection depot.
www.parcelmonkey.co.uk
Parcel2go are a waste of time. And they are based less than 5 minutes from me, and I'm normally all for supporting local companies.
Quick edit: not sure on your weight, but with 20kg, the price is only about £13 with you proper measurements. That's with parcel monkey.
Thanks for that link, the seat is only around 8kg so can get delivery super cheap. Much obliged.
