Hi
When i owned a 5th generation iPod i had THIS . Its an add-on battery you could plug into the bottom (charger port) which extended the battery life for a few hours. Is there anything similer for the itouch?
I’ve found an "emergency battery charger" on the Bay which seems like it would do the job. Unfortunately it covers the earphone socket when it’s plugged in. Any idea’s? Thanks for your help
