MotherBoard For AMD II x4 955 BE
14 Jun 2010
Hi all I ordered the wrong motherboard (Gigabyte GA-880GMA-UD2H AMD 880G (Socket AM3) DDR3 microATX Motherboard) so looking for new one to go with the follow parts my budget is £90
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3)
Microsoft Windows 7 Home Premium - Retail (Full Version)(GFC-00025)
Lancool Dragon-Lord PC-K62 Mid Tower Case with Window - Black
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3)
Western Digital Caviar Black 640GB SATA 6Gb/s 64MB Cache - OEM (WD6402AAEX)
Logitech MX518 Gaming-Grade Optical Mouse (910-000616)
Pioneer DVR-S18L 22x DVD±RW SATA Labelflash ReWriter - Black (Retail)
Hi there, when you say "wrong" motherboard- what do you mean?
The 955BE will work with the 880G board, it is just a bit on the small side.
However, if you are determined to get a full-ATX board then this would be the board I would go for with that budget.
I mean its micro ATX was in hurry and missclicked, I preffer full ATX boards whats the main diffrence betwee 800 chipset and 700? as i will be buying an extrat 4 GB ram and X6 CPU next year when i come to render to my animation project. Been Traveling for the past year so kinda out of touch.
thx for the reply.
£84.99 inc
why do you prefer an ATX board over a uATX board? :confused:
If you don't need to add a heap of expansion cards you should be fine? . . . uATX is the future for everyone that doesn't need Multi-GPU! :D
This is a tasty ATX board, backup IGP, Heatsinked 8+2 PWM and PCI-E 2.0 Crossfire 8x/8x . . .
ASRock 890GX Extreme3
£99.99 inc
Product Page
Or just choose one from here:
AMD AM3 (800 Chipset)
