Packaging of Samsung monitors
2 Oct 2009
Belfast, UK
Just a quick question as googling does not seem willing to give up the answer.
I know Samsung monitors come with VGA and DVI cables, but does anyone know if they come with HDMI cables if the standard is part of the monitor spec?
If not, is the brand of the HDMI cable significant or irrelevant?
Cheers
They dont ever tend to come with HDMI mate only VGA and DVI leads, and i personally would go for the cheapest cable you can find...ive used lots £9.99-£99.99 leads and rarely see the difference!
i know if you stream 3d using 1.3 HDmI the mega expensive ones tend to be able to stream the higher bandwidth required but not much else
+1
Last purchase from OCUK contained VGA and DVI but not HDMI. Got cheap HDMI lead from the auction site. No problems with image quality.
Some Samsung monitors don't even come with DVI cables. None of them come with HDMI cables.
