Hi,
Having some problems getting 3.4GHZ prime stable.
Firstly ive got 3.2 stable using these settings:-
360x9
Ram 1:1 (720)
cpu v: 1.4v
ram by spd
ddr2 v: auto
mch: 1.37
Now this is stable and pretty cool, max core temp is 61. And the IP35's infamous PWM temps only hit 55. The core voltage under load is 1.34-1.36v.
Now my chip has a pretty high VID (1.325) but is the G0 stepping revision.
So I have been trying all evening to get 3.4 stable.
Using:-
380x9
ram 1:1 (760)
Now Ive been steadily bumping the vcore all the way from 1.4 to 1.51 and it still blue screens after 5 mins of prime.
The higher the volts go the longer prime will run, however my PWM temps seem to reach 60 just before it blue screens. Temps @ 1.51 v were under 70.
So, is it my PWM that is holding me back? My cooling? Settings?
Ideas would be appreciated!
360x9
Ram 1:1 (720)
cpu v: 1.4v
ram by spd
ddr2 v: auto
mch: 1.37
Using:-
380x9
ram 1:1 (760)
