Who removed my sig and WHY?
Status
Not open for further replies.
Caporegime
22 Nov 2005
it does not break the forum rules or im having a brainfart?
http://snoop1050.pwp.blueyonder.co.uk/Untitled-1.jpg
400px × 75px IT IS EXACTLY THE RIGHT PIXELS?
19.7 KB (20,242 bytes) IT IS 0.3KB UNDER THE MAX FILE SIZE?
What is the signature for? [edit your profile]
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted
IT DOES NOT CONTAIN MOSTLY VERY LARGE WORDS
[TW]Fox;17441609 said:
20242 > 20000?
It wasn't a very good Sig anyway so don't worry.
dont be anal in Kb its under by 0.3! how many bytes are in a Kb 1024? acording to google 20k in bytes is 20480 so im still under
The rules state kb, not bytes, so I would have thought it was fine.
1024 bytes in a 1k , 20k = 20480 im fine my sig apears legal to me
Best bet might be to email an admin?
admin wont know one of the mods might, im honestly curious as to why my sig was removed when i made this sig months ago i was very anal about it meeting the board requirements because the sig i had before it slightly broke the forum rules
It shows as:
Size 19.7K
Size on disk 20K
20K=20480
There is nothing wrong with it.
The Signature Is Legal.
Does someone sit here viewing the properties of every sig?
i can only assume someone reported one of my posts to a moderator claiming my sig breakes the forum rules but im pretty convinced it doesnt break any rules
1024 bytes in a Kb im clearly under 20k.
can i put my sig back or what :S
Status
