New Case! Now what?
upload the picture you want too use to Photobucket/imageshack, then just copy and paste the link (including,
on eitherside)
I've got the model of case below yours (K58), and have all the cables running behind the motherboard tray, so it's totally clear in front. You can take of the other side of the case to the one you'd take off to work on the motherboard, and run all the cables back there.
Here you go. Have now got an extension to the fat PSU cable running across the front, and that's going round the back too. Nice and easy. About half an hour's work to get it tidy like that :)
http://forums.overclockers.co.uk/showpost.php?p=15007451&postcount=2791
that works, but the link already has tags applied, so the other two arent necessary.
edit- can you make the image bigger? 800X600 would be a nice size
Thanks. Any suggestions about the wireless internet card not working.
is the card a new item you have just fitted along with the new case? does it appear under device management? maybe with a yellow warning triangle next to it?
added a little edit to my previous post too.
I can't seem to get the picture to be larger. In the device manager the internet card has a small yellow triangle next to it.
Thanks again.
open the photo in something like paint, and resize it to 800X600, save this, re-upload, and then post this new picture.
you tried installing drivers for the card? got a disk with it? or visit the manufacturer website?
Yes, however I cannot find any Windows 7 drivers for it but it worked before with Windows 7 in my previous case. I've also just edited the size of the picture on the first page.
try uninstalling the device in device manager, rebooting the pc, and seeing if it then tries to install again?
or right click the card, and update the driver, let windows search the net?
or pull the card out, start the pc up so it then knows the card has been removed, turn off the pc, stick it back in.
long winded I know, but hey.....
Tried the first option: Uninstalled, rebooted, then a window appeared named "Driver Software Installation". It says "Belkin N1 Wireless Desktop Card #41 Ready to Use" with a small green tick next to it. However there are no wireless connections to be found.
unfortunately now I cant help anymore, wireless cards and setting up the internet connection with them isnt my "thing"
maybe try the Networks & Internet Connectivity forum.
