Printer sharing
4 Jan 2003
Hampshire & Spain
Is there a simple way of sharing 1 USB printer between 2 or 3 computers, e.g. Connecting to Router via Ethernet port?
If so what do I need?
Thanks
Syd
you will have to plug printer to one pc and that pc will need to be on for the others to print
go to printer/ sharing and share it
on the other pcs go to add printer, add network printer and it should search and find it
/assuming you have all pcs plugged in to your router and depending on what version of windows you have running
This is the method I use now, I was hoping there would be a better way
Syd
Buy an HP Jetdirect printer server. These things are the bees knees. I have one, and it never falls over. I have tried other print servers in the past, and always found them to be awful.
