The game is only just playable with its current graphics on maximum unless you have the best of the best so any graphics mod will make it unplayable. There was an Avatar mod which had gorgeous graphics for it but it was pretty much unplayable. Not sure about warhead as its a little easier on systems in the first place though. Cant wait for the sequal or something?![]()
I tried that extreme quality mod, bloody hell. It's the best ingame graphics I've ever seen.
This is the later version of extreme quality (3.0.55), it's amazing, and you can get a good solid 40+ fps on good systems.This also omits the TOD file of the earlier video, so less OTT brightness and whatnot.
Truly amazing IMO!
when you say good system something like top end i7 with 8gb ram and a 5970
I love reading utter nonsense posted as fact. At least it's entertaining... unless you have no reference to realise they are talking crap.
OP the mod you're looking for is called "The Official CCC CUDAATS 2.21" and it absolutely rocks. You can completely see the graphical difference when you install it. Sorry I can't provide a link but that's the name... there may also be a newer revision of the CCC mod but this is the version I used a couple of years ago and I was immensely impressed.
check the amazonian mod![]()
i didn't see much difference with this mod altho i've only played with this mod for about 30 minutes from the beggining of the game, i'm wondering if it applied the data properly
CCC is definatley the best performance/prettiness balance.
