Quiet or passive cooler for E8500??
17 Jan 2007
I've got a HTPC running a E8500 (not o/c) with an Akasa AK-960E cooler.
It's too noisy - and on my Gigabyte M/B speedfan and the like don't work... I had to resort to putting a resistor inline, and it is still too noisy..
So.. any recommendations for a passive cooler or a very quiet cooler?
I would prefer not to have to remove the M/B if possible, but I guess if I have to then so be it..
Also, it's in a Zalman HD503 case, so I believe the cooler must be less than 125mm in height..
Ta!
If you are not over-clocking the CPU a stock Intel cooler will work rather well and surprisingly it is not very noisy. I doubt that you will hear it in your HTPC case. Assuming you do not overclock - which as you said you do not.
Seriously try it you will be surprised.
That looks like it would fit.. noise is 24db - the one I have now is 30db so an improvement, but I don't know how much quieter that translates into!!
The other one I was thinking of is the Scythe Shuriken BIG Quiet but I don't know if it requires the M/B to be removed..
Hmm.. I may give one a whirl then... Cheap enough, so prob worth a gamble..
I am using a Silverstone NT01-E with an Intel E8500 running stock in my Silverstone GD02 case, seems to be fine. The other cooler I was looking at was the Silverstone NT06-E.
This is in a pretty full small case with a passive cooled HD5750 as well, it can gat a little warm within the case when playing games so I don't OC. But it is silent at a foot away there is only the light showing the PC is running, I have to put my ear to the case to hear anything.
At stock in both my GD02 and LC13 cases I find the Intel stock coolers way too noisy.
Add to that you should also try UnderVolting the processor and you will almost certainly not need any 3rd party cooling . . . the CPU will hardly get warm and the mobo should lower the stock HSF to minimal rpms . . .
