How am I meant to shave 3KG of faaat and beat 180KG without someone holding my hand?Told you before, you are a potential record breaker. A few comp grade reps and you will be best in UK![]()
It's not fat you have to drop, it's weight
There are a few guides to dropping weight before a comp, but it's only really effective if the weigh in is a day before rather than on the day!
You have it in you, I can tell fella![]()
Very impressive. Question - how much was your spotter helping? It's not obvious from the video.
Ah I see. Have you ever competed before?It's not fat you have to drop, it's weight
Spotter just had his hands touching me.Very impressive. Question - how much was your spotter helping? It's not obvious from the video.
I'm very weak at squat, have bad knees and my back plays up. Most I've managed is 130kg at 75kg.
Just a point to note, I can almost touch my arse the ground, but at that depth by arse also starts to "tuck in" - which is (for me at any rate) owing tight hamstrings and tight TFL. So although I can get deeeeeep, my form actually breaks.
