So my A5 Bora has had it's first ever failure. Not bad considering I've put 95,000 miles on the clock since purchase.
The driver side window stopped working so I thought it was the switch assembly in the door.
1.) I took the switch assembly apart and it was as brand new as the day it was made, I checked for continuity and it's working perfectly.
2.) I replaced the window regulator since my scrap yard had the exact same model, the serials matched, it was dirt cheap and we tested it as functional. Didn't do a thing.
What on earth can I try next? I had an instance where the window started to drop after the switch broke and I pulled the window up very gently and it's never fell down since. So my next step is to dismantle the entire door to access the window arms and check if anything is stuck or preventing them from lowering. That's going to be a ton of work since they use multiple plates to strengthen that area and there's risk of damaging the arms and the handle release bar.
Anyone encountered else this issue with their Vdub or have suggestions?
. Surely a joke.
