£600 gaming spec please
14 Dec 2009
Hi Guys,
I've got a friend who needs to build/buy a new system for around the £600 mark. He can go to like £630 or w/e so don't worry for getting it BANG on budget.
I specced him an AMD rig and an i5 rig.
Both of these used the GTX 460 768mb gfx card for around £120, OCZ Stealth2 600w, Sammy F3 1TB HDD, Antec 300 Case, 4GB PC12800 Dual Channel RAM and a CPU Cooler (Titan Fenrir or Artic Freezer v2) and cheapest optical drive.
I used the AMD 955 and the i5 760.
I've told him that the i5 760 generally will do better for gaming (correct me if I'm wrong)
I'm looking for confirmation on these specs, any problems with them or alternative specs with changing the gfx card maybe or whatever you like. For example should he go for i3 combo but up the gfx card?
He's happy to buy OC bundle or individual parts or even a full system.
Any input really would be helpful
He will be gaming on 22" @ 1920 x 1080
He needs the full tower, no OS, no monitor
Thanks a lot,
Wu
EDIT: Recommendations on mobos that go with those CPUs within budget would REALLY be helpful. Can't remember exactly which ones I chose but at this budget there's only a choice of like 1 or 2 anyway...
With a 1080p monitor I'd say you definately want to squeeze in a 1GB 460 at least in the GPU department. The 768MB will be struggling in some titles at that res. If that means sticking with AMD for the CPU so be it.
This is what I've got for him so far including VAT + delivery - anything wrong with it? Can it be beaten by something/someone?
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £146.86
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card £124.98
Asus M4A87TD Evo AMD 870 (Socket AM3) DDR3 Motherboard £86.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £76.36
OCZ StealthXStream 2 600W Power Supply £58.99
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
Antec 300 Three Hundred Ultimate Gaming Case - Black £43.98
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) £18.99
Sony Optiarc AD-7260S 24x DVD±RW SATA ReWriter (Black) - OEM £15.99
£15.99
Total : £632.82
Aaah - right. Yeah I think that would mean going AMD over Intel - you sure about the performance drop with the 768mb wouldn't be the same with performance drop of Intel going to AMD ?
Your basketProduct Name Qty Price Line Total
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card £164.49
(£139.99) £164.49
(£139.99)
(£124.99) £146.86
(£124.99)
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard £104.99
(£89.35) £104.99
(£89.35)
(£64.99) £76.36
(£64.99)
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply £56.99
(£48.50) £56.99
(£48.50)
(£37.43) £43.98
(£37.43)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £32.99
(£28.08) £32.99
(£28.08)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
(£11.91) £13.99
(£11.91)
Sub Total : £545.24
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 17.50% VAT : £97.60
Total : £655.34
unfortunately your cpu is intel and you have specced a AMD motherboard.
(£139.99) £164.49
(£139.99)
(£124.99) £146.86
(£124.99)
(£89.35) £104.99
(£89.35)
(£64.99) £76.36
(£64.99)
(£48.50) £56.99
(£48.50)
(£37.43) £43.98
(£37.43)
(£28.08) £32.99
(£28.08)
(£11.91) £13.99
(£11.91)
Sub Total : £545.24
DPD Next Day Parcel
Total : £655.34
sorry yes it's because I was speccing both options and forgot to take out the AM3 board. : D
Thanks for the spec though stulid
do you think the PSU will be enough at 500w? Not worth going for non modular at similar price at 600w? And although I didn't say that he would be overclocking, he probably will therefore do you not think he would need a CPU cooler other than the stock or would that be sufficient up to say 3.4 Ghz on the i5 760 chip?
Under budget and includes a cooler...
Asus P7H55-M/USB3 Intel H55 (Socket 1156) DDR3 microATX Motherboard £79.99
OCZ StealthXStream 2 500W Power Supply £45.99
Xigmatek Asgard Midi Tower Case - Black £28.99
Cooler Master Hyper 212 Plus (Socket AM2/AM2+/AM3/775/1156/1366) £19.99
Sub Total : £518.86
DPD Next Day Parcel
VAT is being charged at 17.50% VAT : £92.99
Total : £624.35
I know it's an matx mobo, and my preference is also full size atx. But unless you're spending even more (around £150 - impossible on this budget) to get one supporting x-fire/sli I can't see the point going full size. What do you get for your extra £25 going for the cheapest full-size atx? A longer board with more slots to remain ever empty. Meh.
Sub Total : £518.86
DPD Next Day Parcel
Total : £624.35
Definite food for thought, thanks Liampope
might as well chuck in a AMD system
(£139.99) £164.49
(£139.99)
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £117.49
(£99.99) £117.49
(£99.99)
Asus M4A87TD/USB3 AMD 870 (Socket AM3) DDR3 Motherboard £86.99
(£74.03) £86.99
(£74.03)
(£64.99) £76.36
(£64.99)
(£48.50) £56.99
(£48.50)
Coolermaster Elite 430 Case - Black £41.99
(£35.74) £41.99
(£35.74)
(£28.08) £32.99
(£28.08)
(£11.91) £13.99
(£11.91)
Sub Total : £503.23
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 17.50% VAT : £89.90
Total : £603.63
single GTX460 card yes, your budget doesn't really allow a motherboard that does multi gpu support, unless you go AMD, then its crossfire only.
HDD size can be a minor thing.
If you are not going to store all sorts of junk on your PC you dont need a 1tb drive. Heck, 40gb is more than enough to run Windows 7 and a bunch of programs, so splashing out on a really fast massive hard disk may be a waste of money for some people.
UMM... Sir the HDD is not a minor thing (if you mean hard drive by hdd).
Yeah, imo the HDD itself is prolly one the top most important components. Hence buying an SSD for £200 a while back.
But I did say HDD size not just HDD. And going for a sam f3 500gb vs sam f3 1TB is simply about storage at that price/performance point.
