Fair enough. The OP might think it's worth flying via somewhere for a better flight though. Although the cost will certainly increase..
Generally connecting flights are cheaper than direct ones.
This depends on airport taxes, amongst other things. Flying through Germany = €€€[TW]Fox;17462334 said:Generally connecting flights are cheaper than direct ones.
I'm pretty sure priority check-in with SA Silver is standard though.
Gold joins the First Class queue, Silver the Business Class.
Makes sense. Unless you fly via somewhere else instead of LondonI will be going from Belfast to Heathrow so don't want any more change overs. Nothing booked yet.
Not sure why anyone has rated Virgin's entertainment system.
The current best V-Port is very dated and the screens are terrible, the video quality is really grainy.
Last two Virgin flights I've been on, the only function I have used is the moving map.
If you fly Virgin pack your own entertainment.
United economy is pretty poor if you are one of the older 772's.
Companies still fly 772s for a major prestige route such as transatlantic??
[TW]Fox;17502931 said:I did pack my own entertainment but didnt feel the need to use it. Decent selection of very new films. It's no 50" HD TV but its fine for inflight entertainment.
how tall are you?
if you are over 6ft you have to go premium economy, anything else doesnt bear thinking about.
[TW]Fox;17502989 said:Why wouldnt they, they are hardly old planes
They are still in production, why would companies not fly them on long haul routes given the 777-200ER is an Extended Range aircraft![]()
I didn't say it wasn't modern, I simply said usually transatlantic routes got the latest and greatest.
Continental are still using 757s as far as I'm aware, along with the rest of the major US airlines..Companies still fly 772s for a major prestige route such as transatlantic??
