- 3 May 2004
- Kapitalist Republik of Surrey
It has made cash fares more expensive for everyone else. This is extremely annoying if you forget your Oyster card and only need to make one or two journeys. If you have a prepaid Travelcard loaded up on it you have to watch it like a hawk because nothing tells you what date it runs out unless you check it at a ticket machine on the underground, then you get charged for a single fare on top of your travelcard rate. Plus, on top of my Travelcard I have to keep a minimum topup loaded on it or it doesn't work.[TW]Fox;17445487 said:What can be simpler than simply touching a card? It's a great system because it automatically ensures you are paying the least amount possible.
Travelcards are expensive, especially when you find you've not made enough journeys for it to represent a saving! This doesnt happen with Oyster.
Don't try me on this Fox, I use an Oyster card every day and it regularly catches me out if I don't pay attention. I know what it does and doesn't do. If you're not used to them it will sting you.
