f1 2010 with xbox360 controller?
24 Jan 2007
hi
before i order this game, i would like to know are the controls fully configurable? because i like the driving controls (forward, revece, left, right) on the right analog stick .
yes i'm using an xbox controller
but can the driving controls (forward, revece, left, right) be configed to the right analog stick ?
on some driveing games the forward, revece can only be used on the 2 front buttons, which is no good for me.
I couldn't find a way to re-configure any of the buttons on my 360 pad - wanted to change the gear up/down buttons to be the same config as Forza 3.
Might be able to change settings in some .ini file somewhere though? Haven't looked. Check the Codemasters forums.
Instead of selecting the Xbox 360 controller profile, set it to 'Custom' Then configure the controls.
the manuel says this:
You can customize the controls exactly how you like them in the Options menu, or just use the
defaults shown here:
if the driving controls (forward, revece, left, right) can't be configed to the right analog stick then i won't be able to play it...
that why i need to be sure 100%
can someone with a xbox360 controller try to config the driving controls (forward, revece, left, right) to the right analog stick, and please let me know if it works..
Thinking of getting a 360 pad too, Ocuk dont have them in stock atm.
a lot of games are good for using a pad and platformers+driving games are deffinately much better then with a keyboard.
You will be able too. I cant imagine that every other controller is fully customisable but the pad that most people have isnt. Use the custom setup rather than the 360 controller and every button can be set to whatever you want. Using a random £10 playstation immitation but getting a 360 pad tomorrow, custom control setup allows you to set whatever key to whatever control.
hi
anyone???
YES, you can. I JUST DID IT.
Set the profile to Custom, and you can assign the right analogue stick to control the steering :)
Just to ask, you have all the driving controls on 1 analog stick? Thats crazy, completely, it means you cant go round corners on full throttle?
yes you can as i have allready said, but i would use right as throttle/brake and left as turning left/right?
