Check My Spec Please
28 Jun 2010
UK
After deciding to go for it I have tweaked my spec a bit just wanted a few expert eyes to go over it before I hit the buy button really.
Went for a small SSD to tide me over till the G3's hit. Also I know i could go for the Samsung F3 But i personally prefer the WD's
Just need some help on Fans really, i have no idea what fans i will need for my case and should i get a better fan if i want to OC (never OC'ed before but seeing as i have a i7 i might give it a go)
Think i saw this reccommeneded at one stage: http://www.overclockers.co.uk/showproduct.php?prodid=HS-010-TI
Haven't gone for 2 460's as i don't see the point at the moment may do in the future.
Thank you very much :)
the case doesn't really need any extra fans, the "lite" version does.
great spec, all will work and be compatible...
Your dots worry me, have I got something wrong? And do i not need a CPU cooler better than stock If i will OC?
Neph09, why are you spending £1500 on a PC . . . have you been reading those magazines again! :D . . . could you actually tell the difference between that machine and a £500 machine for the tasks you intend to perform? . . i.e your "needs"? ;)
I estimate It to last me 3-5 years So £1500 isn't a lot for 5 years really. Seeing as the spec stock is excellent and it can be overclocked, plus when upgrading things like my Screens, case won't need to be changed really the screens are costing £360 of the cost.
Take that away its £1100
And yes i can tell the difference between a £500 and £1500 machine thank you.
I do agree on getting a nice case/psu and quality screens that will last multiple builds.
how about a cheaper samsung F3 1tb drive? thats one thing you wont notice the difference on.
Really? . . . how? :confused:
I'm just asking a polite question btw? ;)
Well a £500 machine would barely cover my 2 screens and a case, i wouldn't have much of a pc without the other bits :)
I considered the Samsungs after hearing so many good reviews of them on here, just they are a tad slower than the WDs.
Although i might change it out can't decide i just do like the WDs :p
Oh don't be daft, you saw I adjusted the £1500 price down to £1100 to cover the monitor and that! :p
So just the towers . . . £500 quid vs £1100 quid . . . how would you tell the difference in actual use . . i.e the stuff you do . . i.e your "needs" :D
Maybe the SSD is obvious . . . what else?
I suppose I am purchasing for the Future, i could save £60 on my i7 save £40 on the board.
But I'm putting myself in a position so that i can add a second 460 at a later date i have a PSU that will handle that. I can OC the CPU when i need it to push a bit more out and i have the ability to upgrade to 24GB and faster memory.
The games and stuff i want to run would run on an i5 but i think I am purchasing stuff that should keep me going for a fair time.
And the SSD is obvious :p
all good points, and imagine in say 4-5 years you wanted more power, wonder how much a 6core i7 980/970 cpu would be then?
plus Crysis is a resource hog!! lol
A friend is really telling me the F3 are better, so I'm really considering changing it.
Is there a difference in noise on the Samsungs Vs WD i'd rather quieter even if i have to pay the extra.
between the SAMSUNG F3(not the slower ecogreen), SEAGATE barracuda 7200.12 and WD black, there is nothing to pick between them, the 6gb sata 3.0 interface on the black is a bit of a gimmick, a harddrive will never fill out that connection.
heres two reviews from the same site, so hopefully the scores can be compared.
http://www.xbitlabs.com/articles/storage/display/1tb-2tb-roundup-2.html this one has the WD black with the fancy sata3.0 connection.
http://www.xbitlabs.com/articles/storage/display/1tb-hdd-roundup-3.html has the standard SAMSUNG F3
£1512.65
Your purchasing for the future? . . . what does that mean exactly :confused:
Oh I see . . . so your benchmarker or? . . . don't you think having one cutting edge GPU is enough to play any game comfortably . . . do you actually think you need two expensive GPU's to enjoy gaming? . . . what happens when a new GPU is released that slaps your Multi-GPU set-up performanc wise? . . are you going to whip out and sell both your GPU's . . . You really don't see that MultiGPU is more about the manufacturers being able to sell you two expensive GPU's instead of one! :p
You don't need to spend hundreds and hundreds of pounds to be in the position to OverClock? :confused: . . . and you really won't be needing 24GB of RAM anytime soon will you? . . . and two 24" monitors wtf? . . . how did you convince yourself that was a good idea . . . i'm genuinely interested in why somebody thinks having two massive 24" monitors side by side is neat? . . . what Monitor are you suing atm?
Here is a spec, that apart from the singke monitor and apart from the chassis comes in at under £1000 and I want to know what you do that would show a difference to you in actual Real-World useage?
That saves you £561.63 which appears to mean nothing to you? . . . all the new technology coming out in the next 3-6months to replace the older tech . . . are you really going to be parted with so much cash £££ for Intel® Core™ i7 technology that launched in November 2008 :D
£561.63 in your pocket . . . apart from the "humble" single 24" HD monitor what are you missing? :cool:
I've been using 2 screens at work for years far enjoy having 2 screens.
All of what i said is hypothetical not sure why your on my case.
I'm not buying a second GPU now nor more RAM or anything but in say 3 years if i need more ram or a better GPU i will guarantee the prices will be far cheaper than they are now and i will be able to upgrade what i have for a far less that building a new PC.
Personally 4GB of RAM is the minimum to have now and i would prefer 6gb.
Also if your going to buy a DDR3 board why use Dual channel? Bit pointless?
Dont really care for bench marks but from what i am Speccing myself i see future for anything i want to run and the ability to upgrade if i need to.
Your arguments saying that i won't need it soon is true i don't disagree. But thats what I'm trying to explain its the future in 3 years time i may find i need 12Gb ram i don't even have to swap out what i have i can just add 3 more sticks and i have 12GB
Again Multi GPU I'm not going to be purchasing that until i Need one and i may never need it if my Games don't ever tax the system. No i won't whip them out if something new comes along.
I don't care that it launched in 2008 are you telling me a core i7 sucks because it launched in 2008? Really?
My aim will be to skip the Sandy Bridge generation, and they upgrade in 3-5 years time, i will pick up an Intel G3 at some stage a 300gb one possibly so i can run all my programs on that.
But i really think my spec puts me in a position for now and future.
Also not quite sure how you don't understand what i mean by, 'for the future' I realise you can never future proof computers. However like above i have put myself in a position thta i can buy in say 3 years time RAM, a second GPU and even if needed the highest i7 far far cheaper if i need the upgrade.
Hello Neph09 :)
Ok fair enough . . . are they both 24" screens you have at work? . . . I did a home system a couple of years ago for an FX dealer who needed heaps of windows open to display various financial information . . . he had a big budget and a "need" so it all kinda made sense . . .
Ok so its a tea break and he is staring at a blank desktop but moments later both screens were filled with live financial data . . .
I'm not sure from what you described how you will benefit from a similar set-up? . . . I wonder did you consider something like a 40" LCD TV with the machine linked up via HDMI . . . It totally rocks for gaming and wouldn't cost you much more? . . . any thoughts?
I'm not on your case? . . . I am discussing your ideas and examining your reasoning behind your rather large spend on your new system? . . . If you know something I don't know then I will have learned something by having this chat . . . conversely if I know something you don't know or didn't previously consider you will have learnt something from this chat . . . it's a two way thing? :)
Now what do you mean "All of what you said is hypothetical" . . . what part of your purchasing decision today is not well supported by available evidence? :confused:
I have a different idea about this which is its better to pay less and buy the technology you actually need . . . then in 2-3 years swap-out the CPU/Mobo/Mem(?) and replace them with something more modern . . . assuming all else is equal nothing else has to be changed . . . the only downside to this is that you have to undo a few screws and remove the mobo and most likey re-install your O/S and then of course flog your older CPU/Mobo/Mem combo @ auction . . . . the upside to this is that you get a much better system to deal with your "needs" of the future and the older hardware fetches a decent price which goes someway to paying for the newer kit . . . historically I have found the part which depreciates the fastest is the processor with the best prices coming from the top parts on that particular socket (i.e people want to buy the best chip they can for the ancient socket?) . . . the mobo and memory always seem to fetch a good price particularly if you kept the boxes and all accessories . . .
In short, with the savings you could make today by purchasing lesser kit and combined with the value to get for flogging your kit down the line means you will "always" have a better PC than somebody who buys top-end today and runs it into the ground for five years + . . . . a faster PC in the future and more money in your pocket £££ . . .
Of course this depands entirely on what you are actually doing with your PC . . . if you feel that 4GB is not enough today then why don't you go "SuperSize" with the Dual-Channel and double up to 8GB? . . . your spec includes 6GB for £139.99 when you could have 8GB for £159.98 (an extra £20) . . .
Sorry I don't follow? :confused:
What has DDR3 got to do with Dual-Channel or Triple-Channel? . . . do you know something I don't know? . . . if so please enlighten me? :)
Just for the record here are two comparisons showing the difference between Dual-Channel and Triple channel on the Intel® Core™ i7 platform
Intel Core i7 Memory Analysis – Can Dual Channel Cut it?
TweakTown Nov 24, 2008
Intel® Core™ i7 Dual-Channel vs. Triple-Channel Memory Mode
InsideHW Friday, 20 March 2009
Yeah I agree benchmarking can be a bit dull, only really found it useful myself to find out if the settings I am changing in the BIOS are improving the performance of the machine or making it worse! :p
I'm not against the idea of upgrading in the future, the point I am trying to make is that you don't need to spend such a premium for the luxury of being able to upgrade? . . . and both machines specc'ed in this thread are not going to need upgrading anytime soon with the exception of perhaps Memory or GPU? . . .
Hmmm . . . your basically saying the six memory slots on the Intel® X58 Express Chipset is something that you value . . . I'm not sure what you actually do with your PC apart from gaming that is actually going to need such a huge amount of memory? . . . Going back in time three years to 2007 2GB was a very good amount with only a few people using 4GB . . . now in 2010 4GB is considered standard with only a few people using 8GB . . . based on that I suppose going forward three years that means 8GB will be considered standard with a few people using 16GB . . . possible problem on the mobo with four ram slots unless 4GB sticks of DDR3 are fairly common by then . . . with four slots and a 4GB sticks that gives you the option of 16GB?
People with 2GB systems from 2007 who want more memory today would take which option
  1. Buy another 2GB(2x1GB) to add to their existing 2GB(2x1GB)
  2. Buy a 4GB(2x2GB) set and sell their existing 2GB(2x1GB)
I've always been interested in MultiGPU but to this day I never tried it out? . . . the reason I never tried it out is personally I found a single powerful GPU always has worked well for me? . . . If I was a benchmarker or has an e-slong that I wanted to dangle on the forums I suppose Multi-GPU would be a bit more appealing! :D . . . . I don't know many people that run a single GPU who eventually add in another GPU down the line . . . the problem there is by the time your single GPU starts to struggle in a game and you think about picking up a second model they are no longer available for sale? . . . you can normally pick them up used though? . . . another problem is that by the time you think about adding a second card their is normally a single card out for sale which is just as fast as your pair of older cards? . . . with this in mind Multi-GPU only really makes sense to me for people who buy both cards at the same time (new) and set-up a stonking benchmarking machine today . . .
Seems a pity to buy a premium £££ motherboard which offers Multi-GPU and a premium £££ PSU which offers Multi-GPU and only ever use a single GPU? :(
No not at all? :confused: . . . what I was saying is that it seems a pity to buy a very expensive product that you intend to last many many years at the end of its product life cycle . . . as I'm sure you know Intel® have been hard at work getting their next big thing ready for release in a few months and your still paying big bucks £££ for something they invented in 2008 . . . it seems to me like money for old rope . . . the price you are paying today is almost identical to the price people were paying in late 2008 . . . I just think perhaps your not getting good value for your money . . .
I see? . . . do you normally do a big upgrade and go with a product that is basically at the end of its life cycle and just before the next big product is released? . . . if so can you explain how that works please? . . . there doesn't seem to be an obvious advantage to this method that I can see? . . . your still paying big bucks and you seem to be happy in doing this . . . I would have thought for someone intending to really max out the system life that buying into a product when it launched was a better idea? . . . seems to be the case for Jonny-OcUK who bought his premium Intel® Core™ i7 system in 2008? . . .he would have been coasting along quite nicely now for two years?
Never heard of an Intel® G3 before? . . . just did a quick gOOgle and it seems to be a new SSD? . . . whats it all about then? . . . and what does this have to do with Intel® Core™ i7 LGA1366? . . .
Ok . . . I don't see what advantage you have with your Intel® Core™ i7 spec over the AMD® Phenom™ II X4 spec "now" apart from spending an extra £400 quid odd? . . . and for the future? . . . well you said something about 24GB of memory and MultiGPU . . . is this likely to happen or is this how you "justify" the extra expense . . . just in case? . . . I don't see that 8GB is going to restrict you? along with the option of selling your older 2Gb sticks and replacing then with 4x4Gb sticks for a nice 16GB? . . . I don't see how swapping out a single 2010 GPU for a single more powerful 2013 GPU is going to restrict you?
If you were going to live on the Moon or someplace where you would be cut-off from the rest of the world I can understand why you would need to "Bulk Up" on technology today? . . .
I can also see that if you were someone who absolutely loathed rolling their sleeves up and swapping out a CPU & Motherboard and perhaps re-installing an O/S would need to "Bulk Up" on technology today? . . .
But I don't see either of these apply to you? . . . what I see is yet another person who appears to have succumbed to a multi-million dollar $$$ marketing campaign who finds himself mysteriously "wanting" a product and appears to have concocted a really flawed set of reasoning to "Justify" actually "needing" to spend a lot more money than is really necessary? :confused:
This notion is only reinforced because you see thousands and thousands of other people doing the same thing and you appear to be following suit using reasons that are not your own and do not really apply to you?
What do you actually do with your computer apart from playing Video games? and why on earth as a consumer are you not interested in saving as much money £££ as possible while at the same time not suffering any obvious technological disadvantage? . . . from everything you have said so far I just cannot see why you would spend the extra £400 odd? :confused:
Thanks for reading . . . and believe it or not I am actually trying to learn something here . . . either that or I am trying to help you learn something here . . . big bucks about to be spent . . . "think" :cool:
I don't use 24" screens at the office and now looking at it i may downgrade that option if 24 seems a tad large for 2 screens.
But personally, I feel what I am buying will suffice, I appreciate all your research however I think i will stick with what i have chosen i generally hold on to the stuff i use for long periods the laptop i have at home that i purchased Has lasted me 2 years going on 3 soon.
There are areas i may draw back when purchasing and after purchasing you never know i may come back and say you were completely right but I think what I am getting is right.
My Spec with 1 24 " Monitor
£1342
Your Spec:
£951
You say the upgrade in RAM and GPU is what i might need hence why I'm avoiding that now. SO with 6gb & the 1Gb version of the GPU
£1262
Your Spec: With 1GB GPU and 6GB RAM
£1025
Now i Have purchased £183 RAM so i can bring that down by 83 for the £105 RAM, I can Change the case sure and My HDD thats another £80 off.
I'm in the realm of Your money with an extra £150 on what I'm purchasing.
You could be right but i'm going to go with my choice thanks.
