Newbie here, so please be gentle.
This has been making me scratch my head for a few weeks now. I've googled all i can and searched on here and a few other forums to no avail.
I'm struggling for stability with new MSI GTX 460 Cyclone 1GB's in SLi on my gaming rig. The cards are stock clocked for now!
Its worth noting the system was 100% stable previously with an older single nvidia gfx card.
I get random system "hangs" in Windows in various programmes (Internet explorer for example, but not just in IE). The PC will not respond to any keyboard / mouse input (but keyboard lights are responsive). I have to hard reset the system. This happens sometimes immediately after booting or sometimes after some time. However its seems to be stable in BC2 and STALKER CoP. I can play either for a few hours without issue.
I can't see this as power related as the cards idle at low power, and gaming is much more stable, but would draw more power. Its not temp related for the same reason, and i have run the case open, and under performance testing temps are reasonable.
Different drivers do seem to impact stability and i have tried various drivers all of which show different crashes. I am currently running on the 259.XX drivers that came with the cards, but i have tried the latest drivers on the Nvidia website and even the latest beta drivers. The symptoms above are for the 259.XX drivers that came with the cards (not the latest drivers).
I run a driver cleaner after crashes and re-install drivers. This is necessary as sometimes the crash screws up the drivers and the PC will not reboot cleanly.
Each card on its own appears to be 100% stable and runs all programs in my rig with no issue (IE included and games).
If i remove all drivers the generic basic Win drivers are 100% stable.
I have seen the PC crash with 2 cards installed (with Sli bridge), and enabled in Windows but with SLi disabled in the Nvidia control panel.
My system is usually o/c'ed, but running at stock clocks has no impact.
My money is on a driver issue / windows bug but i'm stumped as to else to do and what the solution is.
Anyone else had similar issues?
HELP!
Cheers
HELP!
Cheers
/sarcasm
I have also been running with the PC case open whilst testing and monitored the temps as fine. It has crashed sometimes straight from boot. All components are effectively not much above room temp.
