Advice on boiler/central heating
19 Feb 2010
London
Hi chaps,
I'm about to begin renovating a place I've bought - short story, it's currently gas fired and I want to put in central heating, however, I'm a bit stuck at which sort of system would be best/most efficient. It's a reasonably big 3 bedroom Victorian place so will need 7 or 8 rads too.
I'm leaning towards having a conventional boiler + immersion heater in whatever setup there is in case the main boiler goes kaput, so I won't be stuck without hot water. The other reasoning behind this is that I might rent the place out next year and don't want someone on my back to get a boiler replaced immediately when they can buy time with the immersion heater.
What's the done thing these days? I've had the combi idea thrown at me but unsure about them, although I'd like to get rid of the tank in the loft if possible. I'm really not that knowledegable on this stuff (obv won't be doing the work myself, thanks to having lots of tradesmen friends & family but could do with some help considering options).
Cheers OcUK oracles...
How many bathrooms/ensuites with showers/baths are in the house?
My personal recommendation would be a good, correctly sized combi boiler if there is just one main bathroom, anything over that fit a pressurised cylinder and boiler. Combis will struggle if there is a high demand for hot water, and pressurised systems are the most efficient.
If you have a combi, you should be fitting showers that heat their own water anyway. They shouldn't be running off the boiler.
Aye there's 1 main bathroom. No ensuites and none planned. I was hoping to get away with a mixer tap shower on the bath. I'm happy to get a decent boiler, it's one thing I won't go cheapo with because I know how much of a pain in the rear it is when they go wrong :(
Any manufacturers I should prefer/avoid?
http://www.diynot.com/forums/viewtopic.php?t=175736
I had a boiler fella around the other day to look at my 12 year old combi as it gave up the ghost. We managed to get it going again but he said the next time it breaks down I should really think about replacing it. Recommends Broag/Remeha's as they are easier to fit than Valiants. Also mentioned that Worchester Bosch are quite average, they only get by because of the Bosch name tacked on the end.
