Nope all current nVidia GeForce cards can only drive 2 monitors and for nVidia surround you need a pair of cards in SLI.
If your not interested in hardware 3D spanning (nVidia surround) then adding another cheap GPU will let you extend the desktop over 3 monitors.
wont work tho![]()
Why didnt you just buy a ATI card :???
2 reasons, I don't have any display ports and you can't run SETI on ATI.
Fair point on the SETI, but just for reference you can get very cheap VGA adapters for use with a DP port.
You dont need sli to drive more than 2 screens. For surround you need sli but for independent display you can chuck any gpu supported in the nvidia drivers into the mix for extra screens.Zotac are going to make a gtx460 that can do up to 4 monitors. without the need for sli.
http://www.bit-tech.net/news/industry/2010/09/23/zotac-announces-the-first-quadruple-display/1
You said you would use a normal card and a crappy vga card for third?
Well if you try and play a game spanning these monitors it wont work, in window mode it will just fail.
