yea you have point but its still going to confuse people if 6870 is slower then 5870 . ^
I agree but come on that is a far cry from the 8800GTS farce!
Yes, but as it's not going to happen, there's no point going on about it.
I just hope the £300 I spent in June on a 2gb 5870 isnt blown out the water by a similarily priced 6000 series card....
Any, the performance is still pretty good so maybe I shouldnt be too unhappy!
a render and processing engine perhaps![]()
how reliable is charlie ? from S A ?
ive been tweeting him about this
" 6870 looks good, and it will hurt NV badly on margins really badly, cant say more though "
he hasnt replied about the 69xx yet apart for telling me that yes they will be the dogs ********
Snip...
when nvidia released the 9800gtx it was arguably slower than the 8800gtx so there is a precedent.
Sloppy though from ATi all the same.
Nvidia renaming issue was SAME core, same speed(give or take) renaming as a whole new series on the SAME architecture with very minor changes.
The naming, is completely irrelevant, it doesn't matter. If ther 9800gt was called a 1000070, or a 99999gt, it would still have been fundamentally a 8800gtx pumped out with a new name to fool people, nothing more or less.
The 6770, 6870, whatever the heck it ends up being called will NOT BE a 5770 or 5870 with a new name to pretend its higher performance, new shaders, different shaders, different cards, different cores, fairly large architectural change. The name is irrelevant, they will BE DIFFERENT CORES.
Nordic's stuff makes little sense, they have the 5670/5570 both as 400 shader cards now, so they can either spread them apart and make the 6770/6670/6570 all very distinctly different performance levels, or keep the same set of names, and move the 6870 up tp a 6970 and then have a dual gpu card as a 6990, IE, it makes no sense at all.
They have a clear and easy naming scheme that follows the naming practices of the last several generations, or they can make the whole 69xx naming a complete nightmare.
Either way, again, it won't matter, a 6770, a 6870 or a Joker XT and Joker Pro, they are different cores, different sizes, different design, different performance and different prices.
People are simply getting confused by what people were irked about when Nvidia "rebranded" stuff, the name meant nothing, it was when there was no change and they wanted to sell the same old thing as new people got mad.
