what screen size you using
I run a 470 with an e6600 @ 3.4 and I'm definatley held back a bit, in some games more than others but still get good fps generally, esp for a 3+ year old cpu.
Easy, just compare CPU usage to GPU usage.How is it possible to tell?![]()
Pretty much. But there's also the matter of how many cores are the game is designed to use.So if a game utilised only 40% gpu usage but 100% cpu usage, would this mean that the game was being bottlenecked by cpu?
Likewise if a game utilised 100% gpu usage but only say 33% cpu usage, would the gpu be bottleneck in this case?
For example, there's this Japanese mmo I play, which I believe is single-threaded (written to only use 1 core). Because of that, my Q6600 is running the game like a single-core 3.0GHz, and my frame rate drop like flies at busy areas with lots of people and my GPU usage is only around 15~20%. This example is that the CPU bottleneck the GPU/graphic card not because of CPU's limitation, but because of the game's limitation.
WOW is also a good example why people having poor frame rate in busy area despite having high end graphic card. The game is written to use no more than two cores (I believe the game was said to "support" more than two cores, but the fact it really only use the 2 main cores), and because of that, lower speed Quad-core CPU actually deliver lower frame rate than higher speed dual-core if both were using the same graphic card. The reason why i3 dual-core or i5/i7 Quad overclocked to 4.0GHz+ deliver the highest frame rate because they are the fastest CPU when being used as a dual-core.
