is it still posible to buy a computer with XP on it?-pls help
14 Aug 2003
cyberspace
Hi,
Does anyone know if it's still possible to buy a computer with XP on it?
If I bought a computer with Windows 7 on it,would I be able to format the computer and install XP on it?
Pls help
I remember those bad old days, having to install 3rd party drivers just to get your SATA to work, then installing a PCI network card because the mobo network drivers weren't supported.
Why oh why would you want XP?
XP is still used in a business environment. To call it pants is 'jumping on a bandwagon' rhetoric. Works perfectly well for us, as it does for countless other business environments. The OP never specified home use or otherwise.
It's only still used in business because of the cost to upgrade. The only way I am getting Windows 7 into client's businesses is buying new machines! :p
Why would you want to cripple a modern system with a 9 year old operating system? It's the equivalent of buying a top of the range Onkyo amp and plugging Alba speakers into it. XP is no longer preinstalled for a reason. The only thing keeping it alive are business' due to the reasons mentioned above.
Hi,
Thanks for the replies:) The reason I want to go back to XP is that one or two programs don't work under Windows 7, example picture it. I use that program a lot to make cards and bussiness cards.
I have tried "compatibility" mode but it still does not work under that either.
Also my printer and scanner don't work under 7 either.
XP is still a good OS. Also my next door neighbour does not want to upgrade to Windows 7 either.
If you get Win 7 Pro, then you get the ability to run a true virtualisation of XP within the OS - best of both worlds!
XP was a magnificent OS in its day (I still use it on my HTPC), but the old girl is showing her age!
If it was me id look at running it in a virtual environment. Use Virtual PC purchase XP Home and then you can start slowly migrating over.
This is what I do with companies that haven't thought out all the compatibility issues. Windows 7 is very secure and is most up to date it would be silly to dump it.
Hi,
I still have a corner in my office with a laptop running win98se, the reason? To run DOS programs. They also demand an epson compatible printer on the parallel port so I have one of those also. VM doesn't cut it with these.
Ideally they should be rewritten, but as they do the job required, no one has taken the effort.
andy.
andy.
VM + USB to parallel converter would sort that.
Hi,
I've had similar problems, I cannot run AKABAK under Win 7 X64.
Take a look at a program called VirtualBox, it allows you to run an XP VM under W7 so you can run your ancient programs. I can now run AKABAK even if it is a bit of a faff.
