ROCCAT KONE+ 6000 DPI GAMING MOUSE
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
The new latest addition to the Roccat arsenal of peripherals is here.
Roccat Kone+ 6000DPI Max Customization Gaming Mouse @ £69.99 inc VAT
With a 6000dpi Pro-Aim Laser Sensor and its integrated Tracking & Distance Control Unit (TDCU), the further development of the prize-winning ROCCAT™ Kone Gaming Mouse has unbelievably more power under the hood. Its maximum precision and ultimate tracking are beyond comparison.
The massive upgrade made to the driver and the introduction of the EasyShift[+] button has also turned the Kone[+] into a real customizable marvel at the same time. No other mouse offers as many configuration options as the ROCCAT Kone[+].
MAXIMUM PERFORMANCE
The revolutionary 6000dpi Pro-Aim Laser Sensor, in conjunction with its 10.5 megapixel resolution and 1000Hz polling rate, offers maximum precision, even transmitting lightning fast mouse movements with up to 30Gs of acceleration and with speeds of up to 200ips (5.08m/s) without loss or lag. Thanks to the Tracking & Distance Control Unit, which is now integrated in the laser sensor, the ROCCAT™ Kone[+] can also calculate the lift-off distance as well as fine-tune the sensor to suit the mousepad. The result: optimal tracking.
ERGONOMIC HYBRID SHELL
The highly praised hybrid shell for right-handers, including the Soft-Touch Surface, have been retained, but really useful core improvements have been made that further increase the comfort of Kone’s successor. The mouse wheel is completely new: distinctive notch positions are perfect for gaming, and the wider design makes it easier to control. The button above the mouse wheel has been made larger and you’ll now find a nicely-sized toggle switch below the mouse wheel. The result: maximum gaming comfort.
22 MOUSE FUNCTIONS
Thanks to the EasyShift[+] button, all the buttons – including the mouse wheel – can be assigned two functions such as macros or other functions. As a result, you now have 22 functions available at any one time instead of the usual 12.
Find out more about EasyShift[+] and just how easy it is to use here: mehr...
4 LED MULTICOLOR LIGHT SYSTEM
Like before, the light system remains unbeaten. Four multicolor LEDs, together with the enhanced lightpipes and configurable effects, can light up, alternate or pulsate in more than four different colors at the same time. It’s a real eye-catcher on any desktop.
5 GAME PROFILES
You can configure your button assignments, including macros, DPI settings, the sensor sensitivity level and your lighting settings too, and save them to any one of 5 profiles on the 576kB of onboard memory. This allows you to customize your mouse to suit individual games. You can associate each profile with a particular application so the right button assignments, DPI and color settings, etc., are automatically loaded when you start the game. When a profile is set as the Windows Profile, the ROCCAT™ Kone[+] will always switch to this profile when you return to Windows after leaving a game or app. Additional profiles can be saved on your hard drive whenever you want, and then loaded to any one of the 5 profile slots using the driver menu.
MACRO MANAGER
Creating and editing your own command sequences is made easy thanks to the highly praised Macro Manager. Predefined macro presets for the top 20 PC games as well as several office apps make it even easier to customize the mouse – plus the new Loop Function now makes it possible to loop macros indefinitely.
SOUND FEEDBACK
The famous ROCCAT voice gives immediate feedback when you change DPI settings, profiles, the volume level or sensitivity setting. As you don’t need to look at an additional display on the screen or on the mouse itself, nothing will distract from the gameplay. It really is as easy at that.
CUSTOMIZE THE WEIGHT
A weight system comprising 4 x 5g weights is included, allowing you to customize the weight in four stages to suit your preferences.
Only £69.99 inc VAT.
ORDER NOW
Very nice, I have absolutely no use for it over my Kone v2 but it's still perdy :D
I really don't need over 1800 tbh, I might get a Boomslang for the novelty, see what it's like, the performance really doesn't bother me too much xD
a lot people complained about the first kone. That it had bad tracking and negative acceleration.
Had my Kone V2 for a year now, couldn't be more pleased. Excellent mouse, better than any Logitech mouse I've had (G5/G7/G9/G500/MXRevolution/MX2000). Tracks smooth, feels great and doesn't have too many buttons like some mice.
On top of that the software is brilliant, the build quality is top notch and it looks amazing.
Not sure this one is 'upgrade' worthy though. :p
I bought one from the MM and sold it within 2 weeks because the tracking was bad and it didnt not seem to be accurate. Maybe the mouse was broke. Or maybe my cloth pad wasnt good enough for it. Online however some people say it tracks well for them and some say its awfull for tracking. I have a roccat sota as of this week. Maybe it needs a decent surface to compliment it. This new roccat also has the ability to turn lift off distance to low.
I just ordered one today :)
What would you recommend for it tho? Roccat Sense or Roccat Sota?
I like the Sense design more but want to make sure it will work well with it.
Sota. I have one and its really good. Mouse just glides. It would go very well with your kone.
