Have recently replaced my trusty E6750 oc'd to 3.6Ghz @ 1.3v, Ram running 1:1 @ 900Mhz, with a Q9550 E0 stepping.
Now i needed to upgrade my mobo BIOS to get it to recognise the chip properly but doing so brought about a whole new set of OC features i wasn't familiar with prior to the flash.
So Hardware:
CPU: Q9550
Mobo: ASUS P5K-E wifi edition.
Ram: 4GB (2x2GB) Geil Black Dragon DDR2 800MHz
Cooler: Thermalright Ultra120 + 1 x Noctua NF-P12
So plonking the chip in and running at stock I have the following temps. (Retrieved using CoreTemp 0.99.7)
- Idle -
Core1: 39°C
Core2: 26°C
Core3: 24°C
Core4: 37°C
- Load -
Core1: 44°C
Core2: 41°C
Core3: 39°C
Core4: 39°C
Obviously i have suck sensors but at least they function on load. 1 core (core1) is a few degrees higher than the others. should i worry about this?
Current Overclock:
CPU: 3.6Ghz (to at least match my previous chip)
FSB - 425
CPU voltage - 1.2250V ( i could probably drop it but haven't had time to experiment)
Ram: 1021Mhz 5-5-5-15 (ratio 5:6)
This runs stable with 1hrs of Orthos and OCCT but will run longer sessions later.
- Idle -
Core1: 39°C
Core2: 29°C
Core3: 28°C
Core4: 37°C
- Load -
Core1: 50°C
Core2: 47°C
Core3: 46°C
Core4: 46°C
Now a few questions.
1) My ram seems to now be set at 1021Mhz. This is faster than my previous speed of 900Mhz, when the E6750 was oc'd with a 1:1 ratio with the FSB. Now even if the Ram is running at 1021Mhz is the ram bottle necked by the FSB (425)?
2) I'm going to run the CPU at 3.8Ghz with the FSB set to 450. Should I then put the ram to run 1:1 and hence the effective speed will be 900Mhz? or should i keep it at a faster Mhz?
3) Temperature. Core1 sometimes can get 6°C hotter than the other cores. should i worry? Should i look at getting a new heat sink to reduce the temps further? or are my current temps ok for air cooling.
4) Apart from CPU voltage, all other voltages are on auto. is this fine?
5) CPU @ 4Ghz is it worth it?
Cheers
So Hardware:
CPU: Q9550
- Idle -
Core1: 39°C
Core2: 26°C
Core3: 24°C
Core4: 37°C
- Load -
Core1: 44°C
Core2: 41°C
Core3: 39°C
Core4: 39°C
Current Overclock:
FSB - 425
- Idle -
Core1: 39°C
Core2: 29°C
Core3: 28°C
Core4: 37°C
- Load -
Core1: 50°C
Core2: 47°C
Core3: 46°C
Core4: 46°C
Cheers
. Also, in another post, you said you were an i7 clocking virgin, seen your 950 results so far, very impressive for a virgin mate, nice one, gotta get this 920 of mine under water, 4.0ghz is a bit boring.
