My NZXT Phantom build
Are you sure about that?
Official site says:
FRONT, 1 X 140mm
REAR, 1 X 120mm (included)
SIDE, 2 x 120mm, 1 x 200/230 (2 x 120mm included)
TOP, 2 X 200mm (1 x LED 200mm included)
He/she didnt buy it from NZXT.
OC have it spec'd to include a front fan...
and no front fan = false advertising...
Even the box says the front fan is included ummmm.
Anyway my build is now complete accept having trouble detecting all 6gb. When you switch on it detects 4gb, but then in windows 7 64bit it says in the computer "6.00gb (4gb usable)" Someone says it might be cos of my cpu cooler too tight, so I will loosen that a tad and see if that works. If that fails I will see if updating the bios does the trick.
Heres a pic of the completed build guys.
No need for commision Phil, just thanks will do:D Cables are really neat there. Shame you aint gonna crank that baby up a bit:) Case looks big like the cosmos.
That build looks really sweet! I know phil from here, as we speak over msn and he's helped me out a lot, particularly with cable management advice when I built mine last year. What's more impressive is that phil is disabled which most people don't know about, particularly his hands and fingers. So to take on something like this and make such a good job of it is very commendable.
Was just having a look at a video review of this case.
Just wanted to know how those tooless optical drive bay clips feel.
Theyre like bendy plastic or rubber arent they?
Does it seem they would be reasonably secure? I mean, obviously, nobody will be chucking a case that huge around much, so it doesnt need screws, but just wondered.
The plastic optical drive bay clips feel nice and strong and wouldnt let a optical drive slide out. My only prob with them, is that thay dont keep the drive very central in the bay as you can see from these 2 pics
Using the clips only
Using the clips and screws
looks very nice.
is it a micro-atx? or just a normal atx? looks like a regular atx to me... but damn you get a lot of space lol
can allways think of things to put there.
looks very nice.
Its a normal atx
Some external shots please, thats what this case is all about, looking like a stormtrooper
I will try to get some external shots for you guys, but with it not being my case, I dont really want to pull all the protective sheets off, but I will see what I can do. If that fails, I think I will be buying a phantom for myself next week, so I'll post loads of pics up then.
Ah yeah, Ive just looked at the box again and it dont say if front fan is included or not:confused:
Its a normal atx
Seems to me that if the front fan didn't mention included then probably it's not included. Same as they stated on the top fan where 2 x 200mm but only mention 1 x blue 200mm is included.
