- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
For a limited time you can buy the HAF X case and receive a free Inferno mouse worth £34.99.
Coolermaster HAF X Gaming Full Tower Case with FREE Coolermaster Inferno 4000dpi Laser Gaming Mouse @ £154.99 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 2.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1
- VGA Holder: 80 x 15mm fan x 1
- PCI Slots: 9
- Bottom mounted PSU
Mobilized to deploy any Storm Ops in heaving light-speed, the Inferno is fortified with an ultra precise 4000 DPI twin laser sensor, a boosted internal 128k Sentinel-X™ memory, and enhanced with our latest patented technology for MMORPGers – the Storm Tactics™ Multiplier key. Designed for total customization, with heavy macro and script capabilities inside, the Inferno is built to actuate ultra fast combo commands – remarkably in faultless precision.
- Superior Gaming-grade Percision
- Onboard Sentinel-X 128KB memory for 3 gaming profiles
- Advance Storm MacroPro Key
- Rapid Fire Tactical Key
- Storm Tactics Multiplier Key
- Rubber Grip / ABS Plastic / Mesh Bezel / Metal Plate
- 4000 DPI Storm Tactical™ Laser Sensor
- Tracks on all surfaces, lift-off distance 2mm
Only £154.99 inc VAT.
ORDER NOW
- PCI Slots: 9
ORDER NOW
