So a 6770 might be as fast as a 5870....meaning 2x 6870 are surely going to be ridiculously powerful!
AMD Radeon™ HD 6800 Series GPU Detailed Feature Summary
AMD Radeon™ HD 6870 GPU Feature Summary:
GDDR5 memory interface
PCI Express® 2.1 x16 bus interface
―Eye-Definition‖ graphics
o Second generation graphics with full DirectX® 11 support
Shader Model 5.0
DirectCompute 11
Programmable hardware tessellation unit
Accelerated multi-threading
HDR texture compression
Order-independent transparency
o Image quality enhancement technology
AMD Eyefinity multi-display technology1
AMD EyeSpeed visual acceleration3
o AMD Accelerated Parallel Processing (APP) technology
OpenCLSupport
DirectCompute 11
Accelerated video encoding, transcoding, and upscaling2
o UVD 3 dedicated video playback accelerator
o Enhanced Video Quality features
Advanced post-processing and scaling
Dynamic contrast enhancement and color correction
Brighter whites processing (Blue Stretch)
Independent video gamma control
Dynamic video range control
AMD HD3D technology
o Stereoscopic 3D display/glasses support
o Blu-ray 3D support
o Stereoscopic 3D gaming
o 3rd party Stereoscopic 3D middleware software support
AMD CrossFireX™ multi-GPU technology5
o Dual GPU scaling3
Cutting-edge integrated display support
o Integrated dual-link DVI output with HDCP
o Integrated DisplayPort 1.2 output
o Integrated HDMI 1.4a with support for stereoscopic 3D
o Integrated VGA output
Integrated HD audio controller
o Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
o Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
AMD PowerPlay™ power management technology
o Dynamic power management with low power idle state
o Ultra-low power state support for multi-GPU configurations
AMD Catalyst™ graphics and HD video configuration software
o Certified drivers for Windows 7, Windows Vista, and Windows XP
o AMD Catalyst™ Control Center - AMD Catalyst™ software application and user interface for setup, configuration, and accessing features of ATI Radeon products.
o Unified Graphics display driver - AMD Catalyst™ software enabling other PC programs and devices to use advanced graphics, video, and features of AMD Radeon™ products.
AMD Radeon™ HD 6850 GPU Feature Summary
PCI Express 2.1 x16 bus interface
Shader Model 5.0
DirectCompute 11
OpenCLSupport
DirectCompute 11
AMD HD3D technology
AMD CrossFireX™ multi-GPU technology3
o Dual GPU scaling
Obviously fake - they blanked out the BIOS version coz they can't easily fake it.
snip!.
Assuming the previous AMD slides that were leaked were correct we know that 6770 is 2/3 6870 (shaders, rops,tmus). So at absolute ideal conditions the '6870' will be 50% faster than '6770'
Thats really daft, can't fake the bios version? no one out of official AMD and select testing partners know the bios number, they could make up ANYTHING. The only reason to hide the bios number is its yet another way for AMD to spot whose leaking info.
No one whos faking it is gonna risk making one up when someone in the know could prove they were just making it up.
Unless they are batch or vendor/feature specific BIOS they usually use generic numbers anyhow so not very specifically identifiable. Granted it could be someone testing an AIB specific BIOS but unlikely.
Drunkenmaster i have enjoyed your posts in the past but i think you have your maths a bit wrong.
When you say this
"As for the numbers mentioned, yes a 4way shader should indeed be more efficient, but it won't automatically be 25% more efficent, that calculation is incredibly, and MASSIVELY wrong. It assumes that its easy to get 4 calculations out of the 5 way shader, and that the 5th is the only one being wasted, its not even close to that"
I think you are missing the point. Assuming that by moving to a 4 way part you are effectively getting room for 25% more shaders units for free (320x5 to 400x4, 400/320 =1.25), and assuming from your example only 1% of the 5th part of the old shader was ever being maxed out (ie effectively nothing - your numbers) then on the new 4way shader these will supply 25% more power for the same area on the die.
Essentially the new 6970 (if the new naming scheme suggested is correct) you'e getting 50% more shader power as previously noted by other people.
By saying the 5th shader unit is never used, then no matter how efficient the other 4 are say "x", by multipling the number of shaders groups by 50% you are still getting 1.5x.
50 percent more shader power for 20% more area (Total shaders 1920/1600 = 1.2
And this power will express itself in the worst of situations the strongest ie mins, as can be seen with Nvidia's more simplified shader designs.
Which is what kylew said but in less words...(oops)
