Nope, but apparently you won't be able to deliver headshots either with it so its not like it makes the wearer super powered.
immune to head shots is pretty super powered tbh.
Well, it's only immunity if you're a sniper, and snipers shooting other snipers is basically the epitome of "how to be almost completely useless to your team".immune to head shots is pretty super powered tbh.
So with this hat and razoback shield you are "spy proof"?
ouch why are people happy to accept this micro transaction stuff ? and in an FPS jeez of all things retarded.
^187
Start the game, open the console (` key, if that doesn't work go into options, on the keyboard page hit advanced, and make sure the 'enable developer console' option is ticked). In the console, start to type in mat_depthbias_shadowmap
It should give you three autocomplete options, one will be the shadowmap one, and afterwards it will show what it is set to, which won't be 0.0005. Just set it to that value by entering:
mat_depthbias_shadowmap 0.0005
In the console.
Thanks for the quick reply, however the only auto-complete things that pop up are;
mat_depthbias_decal -262144
mat_depthbias_normal 0.0f
Typing mat_depthbias_shadowmap returns the error; 'Unknown Command'. I did forget to mention Im using a MacNot technically in the right forum, but seemed like a generic setting/command so I thought Id put in in here :>
The problem is that they are essential to competitive play and you will have to own them too to get the edge. It forces you into buying them .
