There is something going on here! I have a Midgard that I got to review and I happened to stumble across an overview video of the Fractal Design R2. They are almost identical. Same motherboard tray, HDD mounting, bottom fan holder, bottom dust filter, fan controller, poor quality side panel etc...
See for yourself, watch an overview video of the Midgard and then the R2, they are almost identical apart from a few bits and the bezel of course.
What do you think is going on here? Are they either made to the companies specifications and they just buy them direct from a chineese factory? Do they use the same factory to make both but with different designs, but the factory uses stock parts?
